Author Topic: Easy on Amiga 500+  (Read 6811 times)
matbas
Easy on Amiga 500+
« on: May 02, 2007, 07:51:34 PM »
Can anyone tell me if Easy Amos (1992) works on an Amiga 500+?  I am new to Amos and Amiga and wonder if there are any compatibility problems.
Re: Easy on Amiga 500+
« Reply #1 on: May 02, 2007, 10:02:08 PM »
All versions of AMOS should work fine on the A500+.  The A500+ has the Enhanced Chip Set (ECS) standard and Amos will take maximum advantage of this chip set.  The added Chip memory will probably help out as well.
Crashedfiesta
    • http://www.nblug.co.uk
« Reply #2 on: July 06, 2007, 03:46:26 PM »
My first experience of AMOS was Easy AMOS on an A500+ so, yes, it works fine.
Incidentally, did anyone notice that the Easy AMOS manual was suspiciously like the SAM Coupe manual? ;-)
« Reply #3 on: July 07, 2007, 01:45:37 AM »
@matbas
Welcome to The AMOS Factory.  Sam and Crashed are right, Easy AMOS should work great on your A500+.  Let us know how it works out for you.
@Crashed
I had never noticed it, but you're right, I think all AMOS manual covers look a bit like the SAM's manual cover.  Maybe it was an early '90s thing?
