HD installation
Started by frl9lk, 16 Feb, 2007, 07:57 PM
frl9lk
I am having trouble installing AMOS Creator 1.3 to my hd (A2000 running OS 3.1) The installation program consistently seems to write back onto itself. Doesn't make sense to me either...
If you are trying to install with the write-protect tab set you'll find it won't work since the disk will "personalize" itself when you first install it.  Are you booting from the Amos disk when you first start up?
