Due For A 3xx Homebrew Protocol Kernel Update
Started by The Evolution Of Life, September 30, 2007, 10:45:25 AM
I think that PSPUAE is due for an update that would work with the new 3.71M33 Homebrew E-Boot since it seems like DA isn't going to make a 1.50 plugin for the fat afterall, even though he said that he would "I think that he has sold us out on that one"
Anyone else agree that we need a new port for the new 3xx Custom Firmware Protocol Kernel's so that we can upgrade to the latest CF without worrying about our favorate emulators not working?
3.90M33 PSP Phat
0.63 PSPUAE
1GB Pro Duo Memory Stick
No Loaders Just CFW
according to FOL PSPUAE already works on the new firmwares for Slim
Quote from: The Evolution Of Life on September 30, 2007, 10:45:25 AM
Have you got a slim?
Have you tried the 1.00 Eboot in kernel 3.71?
It works fine for me, I always use the firmware kernel, never 1.50 and it all works fine. So it should work for the slim. I am going to look into updating it for the new kernel, but I have had alot of PC problems lately, so im trying to get my PC sorted.
QuoteResolute and Industrious
it ready for Fat PSPs this
1.50 Addon for 3.71 M33 (PSP Fat Only) > http://www.psp-hacks.com/2007/09/30/150-addon-for-371-m33-psp-fat-only/
we wait for and Slim in a few days
My PSP is not fat! It's just big boned that's all...  ;D
On a side note regarding 3.71 Custom Firmware. If you end up in a situation like me and cant install 3.71 M33 on your PSP cause the official updater says your PSP is screwed.
You will need to use the new padora creator, that lets you pandora straight to 3.71 M33. Spent 4 hours trying to get this to install on my son's PSP and it kept bricking, :(.
Hope this helps people who cant update.
Right, been playing round with compiling for 3.71 slim, i need some testers. Please PM me, so i can get it tested.
i have 1 user in my forum whit slim..
FOL if you can send me the right PSPUAE for this firmware.
Quote from: Anemos on October 02, 2007, 06:26:21 PM
Will do, still working on it at the moement
robertfisk
#9
Quote from: FOL on October 02, 2007, 06:59:41 PM
I have both slim and phat . Just send me a pm if you need help with tests or anything.
0.63 works fine on the slim,but it would be great to implement the extra memory in the emulator:)
Quote from: robertfisk on October 03, 2007, 01:18:27 AM
You would really want the extra memory? why, we removed the code as it was pointless. Spose we could readd the code and define for 3.x FW. First I want a working 3.X FW version.
Ill PM test Eboot now.
Ok! the Slim user say run & working good,
his noob and young man and dont know what is Amiga!!
::) :o :o
Quote from: Anemos on October 03, 2007, 06:35:23 PM
::) :o :o
Thanks, but it really need it tested as i found it crashed when selecting adf's, states and configs. That could just be cause im using it on a phat PSP.
cleanoff
i'm using phat psp with firmware 3.71 m33 (currently release2 with v2 1.50 kernel addon). I tried running the kernel 1.00 eboot in game371 folder before AND after 1.50 kernel addon (with both m33 releases) - it seemed to work fine  :)  I did this cos i thought it'd be a good test to see if it works on the slim.
Couldn't get music.prx (version50) to work with pspuae (0.63be) though...  :-\
So is pspuae confirmed to work on the slim - i'm confused  ??? is it not stable or something?
